Brief Description: Left wing leading edge to fuel tank joint plate
Today I installed the left wing leading edge to fuel tank joint plate, see image 1. Then I began preparing the fuel tank attachment Z brackets, see image 2. I also prepared the left wing tank skin by removing the vinyl coating on the inside and along the riveted areas on the outside, see image 3.
